"O"man(are we in trouble)
How many here have experienced DME relay failure?
Did it occur while driving or at start up.
Is this the most common cause of start up failure in your opinion? Last edited by widgeon13; 04-30-2016 at 06:39 AM.. |
Former Options Trader !!!
Start up
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
What?
Start up here as well.
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
Dme
Start up.
Go-Kart Mozart
Startup.
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Ditto.
Rescuer of old cars
Start up for me as well.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Intermittent until it wasn't..
Both. While driving it ended by being a bad/worn fuse on the end from spinning to free up corrosion since I am near the ocean.
I got rid of the problem by going to the updated fuse box using bladed fuses. |
Brew Master
Dead on startup.
911T '72
When my car was delivered it would not start. Even though the PO had driven the car onto into the transport trailer. It was de DME relay.
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
Driving. Turned off when stopped at a stop sign.
Just last week - start up 1985 911 euro. Changed DME fired right up!
How hard is it to change? Can it be done at the roadside, and where is it? Sounds like I should be carrying one!
That Guy
Pretty simple, its under the drivers seat next to the DME. If you have 4-way power you can lift the height of the seat up all the way to get more room for easier access. Reach from behind and pull the plug off. Then from the front you can remove a 10mm nut that holds the relay down to the floor.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
just picked one up from our host and it's in my glove compartment. I feel better
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Formerly known as Syzygy
Put it in your car and try it out. It'd kinda suck to need one sometime and find that your shiny new one you got as a spare is DOA. Doesn't happen a lot, but it does happen...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Good point...that's why I love this forum.
Startup 12 yrs ago. Had no idea what the problem was, so I had it towed to a dealer to get ripped off there. I now carry a spare.
Start up, also carry a spare...
