'78 911 Coupe
Ground Straps
Where do these ground straps go? I have the strap to the alternator on, attached the strap to the transmission, rear deck and CDI. I just can't find in my notes where these two straps came from??? Putting the car back together after two years. Any help will be much appreciated!
1978 911 sc coupe
Old 05-07-2016, 06:23 PM
ROW '78 911 Targa
timmy2's Avatar
Are they the engine lid straps?
Edit: oops saw rear deck.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-07-2016, 06:33 PM
What MY/size engine, 1965 or 2011?
Old 05-07-2016, 10:10 PM
'78 911 Coupe
Edit added: 1978 911 SC Coupe
Old 05-08-2016, 12:07 AM
Your best bet is to go through the electrical diagrams and check them all. I would call this standard procedure after 2 years of rebuild.
Old 05-08-2016, 01:12 AM
cycling has-been
bkreigsr's Avatar
No need to do this - plenty of threads on this topic.
Search>Advanced Search>'ground straps'>search titles only>911 technical forum..
Bill K
Old 05-08-2016, 06:54 AM
'78 911 Coupe
I did look through the electrical schematics. It shows ground but not specifically where on the car or if it is a strap.
Old 05-08-2016, 07:02 AM
'78 911 Coupe
I have located and connected ground straps on G1(deck lid), G3, G4, G8. Notice this diagram does not even list the alternator.
I don't believe there is a ground strap at G2, G5, G6, G7, and G9. Just ground wires.
Still have these two unaccounted for straps! Ahhhh! This is turning into a good mystery novel.
Old 05-08-2016, 10:43 AM
Functionista
manbridge 74's Avatar
Hmm... Maybe added by a PO? Or around headlight bucket area?
We have a partially assembled 78 at work so I'll take a quick look tomorrow.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-08-2016, 11:20 AM
Send a message via Yahoo to mobius911
They look like the noise suppression straps for cars equipped with stereo. Since the factory supplied those in pairs it seems like a possibility.
Usually covered in a black plastic sleeve. They connect to the each side of the hinge mounting brackets on the firewall, then they wind through the hinge and connect to one of the mounting bolts to the decklid.
Jeff Jensen
1973 911
Old 05-08-2016, 11:43 AM
'78 911 Coupe
Jeff!!
You nailed it! I looked at all my pics from when I tore the car down and noticed the red over spray. I did a little research and indeed many of the 78's had two straps to the deck. Both of these straps have red over spray.
So, now I have a new problem! I thought the smaller (narrow) strap in the picture below was my deck strap. So, now the problem is, where does this strap go?
Old 05-08-2016, 01:08 PM
911tracker85's Avatar
hmm... wondered why my 78 had these on the deck lid.
so if I do not install a radio do I need them?
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 05-09-2016, 06:01 AM
'78 911 Coupe
Bob! I'm asking myself the same question. My car had a tail on it and it looked like there may have been a rear wiper option. In that case, it may have needed the extra ground. I also see some threads that indicate the "abundance" of ground straps is for the issue of radio interference.
But my big issue now is, I have an extra ground strap in my hand that I don't know where it goes!
Old 05-09-2016, 06:28 AM
I think the radio ground straps were overkill. More to satisfy some DIN/TUV requirements than to satisfy any functional needs. The CDI box does put off some EMI though, so you just have to try it out and see what happens. And if you don't have a radio you definitely don't need them.
Sorry I can't help on the extra ground strap!
Jeff Jensen
1973 911
Old 05-09-2016, 10:05 AM
'78 911 Coupe
I think I'm going to start a new thread since there is a lot to look through to get to my new issue.
Old 05-09-2016, 10:10 AM
Registered Minimalist
75 911s's Avatar
Thanks didn't know what the point of these was.
Some photos for your reference:
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 05-09-2016, 10:15 AM
Counterclockwise?
How the hell can these things help the radio? lol
I just removed my rear wiper and removed these thinking they were either for ground to the lid or to remove static from the wiper.
Now I don't know!
Rod
1986 Carrera
2001 996TT
Old 05-09-2016, 11:11 AM
A ground for the License plate lights?
Do you have one of those straps between your alternator and the engine block? Behind the alternator.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-09-2016, 01:30 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by Brian Fuller View Post
Jeff!!
The engine compartment fuse/relay panels have a ground strap, between the panel and car body, similar in size to the one on the far left of the picture.
Old 05-09-2016, 04:07 PM
sugarwood's Avatar
I don't see that on my '86.
1986 Bosch Icon Wipers coupe.
Old 05-09-2016, 05:38 PM
