-   -   Horn button ring does not fit when spacer installed under prototipo (http://forums.pelicanparts.com/porsche-911-technical-forum/912614-horn-button-ring-does-not-fit-when-spacer-installed-under-prototipo.html)
n1ne11 05-01-2016 11:01 PM
Hi ! SmileWavy
Added a 30mm spacer under my freshly installed prototipo, unfortunately the spacer is just a bit too thick (too big inner diameter) and the momo horn button adapter ring does not fit anymore, so the hornbutton is loose now.
Do you guys have a solution for this? Any special compatible spacer recommendation? The holes were nice on this one because they passed through the spacer, so no misalign happend.
http://img15.hostingpics.net/pics/642484spacer.jpg
Thanks a lot!
PWICK911 05-01-2016 11:41 PM
I just had the same problem.
Momo do a kit to allow you to use the horn button with a spacer
They sent me one free.
Picture of the issue I had
http://forums.pelicanparts.com/uploa...1462174842.jpg
PWICK911 05-01-2016 11:44 PM
http://forums.pelicanparts.com/uploa...1462175014.jpg
Fitted and all working.
20mm spacer.
I used a self taping screw for the rear earth connection on the horn button
n1ne11 05-01-2016 11:53 PM
Great!
Any link where I can find the kit? or do you have pics of the kit?
Where did you put the screw in?
Thanks a lot!
n1ne11 05-02-2016 07:07 AM
If I don't manage to get a proper setup on this prototipo I will really reconsider the older Ruf Atiwa steering wheel, as it was not that bad. And the positionning and grip was cool, just the looks a bit less outlaw than the Momo.
I searched a lot on the internet, also spacers that would be compatible. I found one that was nicely made, but there is no shipping to EU at normal costs...
I also Emailed Momo in italia but don't have much hop on this one.
PWICK911 05-02-2016 10:06 AM
Originally Posted by n1ne11 (Post 9103147)
Great!
Thanks a lot!
Hello
Sorry no pics of kit,however it consisted of-
Alloy collar which clips into the steering wheel to mount the horn and an earth ring.
I received no paper work with the kit and I have the bag but it was blank
Sorry I can t be more help
Momo doings of this issue and the U.K. Office was only too happy to help
n1ne11 05-05-2016 10:36 PM
I wrote to Momo UK and they basically said to me that they are sorry but there is no solution for not-momo spacers. I would have bought a spacer from them if it was long enough.
Now I am just thinking about mounting back my old Ruf steering wheel. I don't see the gauges that well even with the spacer so...
n1ne11 05-10-2016 04:47 AM
Momo UK says they don't know what I am talking about. Well, I guess I can forget my spacer and will probably have to buy a little momo spacer that shifts the steering wheel up. Hope it will get better for driving position/gauge sight. :D
