LinkBack | Thread Tools | Rate Thread |
Hi !
![]() Added a 30mm spacer under my freshly installed prototipo, unfortunately the spacer is just a bit too thick (too big inner diameter) and the momo horn button adapter ring does not fit anymore, so the hornbutton is loose now. Do you guys have a solution for this? Any special compatible spacer recommendation? The holes were nice on this one because they passed through the spacer, so no misalign happend. ![]() Thanks a lot!
1987 911 3.2 Convertible - Strosek / RUFised in 1994 - Metallic blue |
I just had the same problem.
Momo do a kit to allow you to use the horn button with a spacer They sent me one free. Picture of the issue I had
![]() Fitted and all working. 20mm spacer. I used a self taping screw for the rear earth connection on the horn button |
Great!
Any link where I can find the kit? or do you have pics of the kit? Where did you put the screw in? Thanks a lot!
If I don't manage to get a proper setup on this prototipo I will really reconsider the older Ruf Atiwa steering wheel, as it was not that bad. And the positionning and grip was cool, just the looks a bit less outlaw than the Momo.
I searched a lot on the internet, also spacers that would be compatible. I found one that was nicely made, but there is no shipping to EU at normal costs... I also Emailed Momo in italia but don't have much hop on this one.
1987 911 3.2 Convertible - Strosek / RUFised in 1994 - Metallic blue Last edited by n1ne11; 05-02-2016 at 08:11 AM.. |
Sorry no pics of kit,however it consisted of- Alloy collar which clips into the steering wheel to mount the horn and an earth ring. I received no paper work with the kit and I have the bag but it was blank Sorry I can t be more help Momo doings of this issue and the U.K. Office was only too happy to help |
I wrote to Momo UK and they basically said to me that they are sorry but there is no solution for not-momo spacers. I would have bought a spacer from them if it was long enough.
Now I am just thinking about mounting back my old Ruf steering wheel. I don't see the gauges that well even with the spacer so...
Momo UK says they don't know what I am talking about. Well, I guess I can forget my spacer and will probably have to buy a little momo spacer that shifts the steering wheel up. Hope it will get better for driving position/gauge sight.
