-   -   I searched and nothing conclusive... Wipers come on when I start the 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/912627-i-searched-nothing-conclusive-wipers-come-when-i-start-3-2-a.html)
Ferrariguyma 05-02-2016 05:45 AM
I have a 1986 3.2 and when I start the car, or even turn the ignition to the pre-start mode the wipers come on automatically and do a few passes. I checked the intermittent wiper switch on the dash and it is off. I confirmed it is working correctly. Any other ideas or links to "fixes" would be welcomed and appreciated.
Thanks in advance,
Andrewhttp://forums.pelicanparts.com/uploa...1462193135.jpg
911tracker85 05-02-2016 06:22 AM
mine does this too, or should I say my wipers will occasionally make a few swipes when driving.
pulled the fuse unless needed.
also my high beams are on most of the time.
I had replaced both some years ago ... sigh...
need to pull both switches from the steering column and fix. I have seen the fix for the high beams, and suspect the fix for the intermittent wiper action will be the same.
need to slightly bend the little contact.
here are a couple links I saved for fixing the high beam issue.
http://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html
http://forums.pelicanparts.com/porsche-911-technical-forum/258555-headlight-dimmer-repair.html
good luck.
Quicksilver 05-02-2016 07:30 AM
Check how clean the ground wires are at the post just in front of the battery.
uwanna 05-02-2016 08:43 AM
+1 on what he said! Had a very similar wiper activation problem when I would use the
turn signals, drove me crazy! Traced everything down with an ohmmeter and a wiring diagram, found a floating ground at the body ground mounting point from the battery negative to the inner left fender.
The floating ground found a path thru the windshield washer motor, causing intermittent wiper swipe! Grounding problems can cause WEIRD problems!
I took off and cleaned all the wires under the grounding nut, several of them were quite corroded. Get a can of DeOxit D5 and use every time you rehookup any electrical connection. It cleans,deoxidizes, seals and protects electrical connections, it's awesome stuff!
Amazon.com: CAIG DeOxit Cleaning Solution Spray, 5% spray 5oz: Everything Else
Ferrariguyma 05-09-2016 05:54 PM
Fixed!
Thanks for the ground tip. SPOT ON! Much appreciated
Ferrariguyma 05-09-2016 06:11 PM
Originally Posted by 86 911 Targa (Post 9113662)
Is your intermittent wiper switch on?
no see initial post
problem was ground
