-   -   74S to RS+ spec engine build (http://forums.pelicanparts.com/porsche-911-technical-forum/912739-74s-rs-spec-engine-build.html)
al lkosmal 05-02-2016 04:52 PM
I recently received a 74S engine. Very cool engine with early CIS....runs great, great leak down (4-6% on all cylinders)......however, I have no respect and therefore it must be subjected to semi-serious power producing mods................and so it begins....
video of it running.....
https://www.youtube.com/watch?v=I1QQVyT0We8
off of the test stand and moved to the engine/rebuild stand
http://forums.pelicanparts.com/uploa...1462234489.jpg
Can you say "Triangle of death".....
http://forums.pelicanparts.com/uploa...1462234506.jpg
more to come.....I'm thinking RS+ spec:
EFI/ITBs (surprise)
9.5:1 JEs
E-cams
headers
sport muffler
For ECU I am thinking MS3 and using it to control....
Sequential Injection/ Ignition
COPs
I can then compare it to the AEM Infinity that I used for my last build.
stay tuned....
stf996 05-02-2016 07:11 PM
Subscribed!
Charles Freeborn 05-02-2016 08:12 PM
Not to split hairs, but that air filter snorkel is different than mine. Looks like a later WUR too (can't really tell from photos) so that would make it a '75 or later? What say serial number search?
When p/c's come off, if they're still within spec, I may be interested in them.
-C
unclebilly 05-02-2016 08:32 PM
Al, I did this a few years ago and plan on bringing this car on drive #2 this year.
I ran mod s cams and a RS distributor curve with MSD but with Webers. My cylinders are shimmed to 9.8:1 compression.
You will love it.
75 911s 05-03-2016 05:56 AM
-C
My 75 snorkel is elongated. Maybe its a ROW 74 CIS? I'm curious to know pros/cons of swapping ROW CIS setups to US engines. Is this how I would make my 2.7 165hp back up to the 175 ROW rated HP? I know the intake runners are larger...
al lkosmal 05-03-2016 06:38 AM
Sorry...good catch.....1st pic I posted is not correct, but from a 77S I just sold. I build and rebuild....and i have many pix and inserted the incorrect one.
I deleted the 1st pic I previously posted and here's the 74 engine on my test stand..........
http://forums.pelicanparts.com/uploa...1462286111.jpghttp://forums.pelicanparts.com/uploa...1462286172.jpg
http://forums.pelicanparts.com/uploa...1462286193.jpg
al lkosmal 05-03-2016 07:37 AM
-C
Charles,
Greetings.....posted the wrong pic initially. i've now fixed that problem....too many engines...and I'm easily confused.
I had a local, with a 74S, stop by to see the engine run and he has already called dibs on the parts, but if you are interested, you are 2nd in line.
regards,
al
al lkosmal 05-03-2016 07:44 AM
duane,
My first pic was incorrect and from a 77S I sold last week....I fixed that with some new pix.
Regarding the 165 vs. 175 HP, I believe that the biggest difference is the early heat exchanger/headers vs. the later, more restrictive exhaust. Install SSIs or headers and you are there.
regards,
al
al lkosmal 05-03-2016 07:51 AM
You will love it.
Unclebilly.........I've built quite a few 2.7s to this RS+ spec...it is one of my favorite canyon carver engines to build............
this is a recent 2.7 I built
https://www.youtube.com/watch?v=EWB99lddFew
works well with 3.0s too...
https://www.youtube.com/watch?v=Ig-paaLh2KY
prebordao 05-03-2016 08:18 AM
EFI/ITBs (surprise)
9.5:1 JEs
E-cams
headers
sport muffler
COPs
Hi Al, this setup is good for how much Hp ? 200 ?
Also, when changing to 9.5 JEs, can you keep your existing Cylinders ?
Charles Freeborn 05-03-2016 01:15 PM
Originally Posted by al lkosmal (Post 9104798)
Charles,
regards,
al
Cool. Thanks.
-C
Trackrash 05-03-2016 05:45 PM
EFI/ITBs (surprise)
9.5:1 JEs
E-cams
headers
sport muffler
COPs
stay tuned....
I mean, since you are going ITBs, why not...
Dual plugs?
10:1 CR?
93 or 94 bore? Making it a 2,8 or 2,9. (unless the cylinders are perfect Mahles of course)
S cams. (E cams won't be enough, IMO)
Sounds like a great build and I am looking forward to your progress.
al lkosmal 05-03-2016 06:23 PM
tear-down
The tear down is progressing.....always nice to see the rocker feet looking like new and the cams in really good shape.........Nikasil cylinders still showing the x-hatching, etc.
regards,
al
http://forums.pelicanparts.com/uploa...1462328546.jpg
al lkosmal 05-03-2016 06:40 PM
Dual plugs?
10:1 CR?
Thanks...i have built several 2.7s using this recipe and it makes a great running, dependable, hi-po street/canyon carver engine. It is basically an RS spec, but with higher CR and EFI/ITBs that allows you to take advantage of the modern engine management/ignition/fuel tuning. This RS+ combo does work great with S-cams, but my preference is E-cams for an engine that not only spools up fast, but provides lots of low down grunt. Also, I intentionally keep it at 9.5:1...or at least less than 10.5:1 because, unless your goal is ultimate HP, cost no object, you gain very little for the considerable cost related to that CR increase over 9.5:1 (cost of dual plugging, etc) Same for 2.8 or 2.9 mods in my opinion. I.E......I believe that for my build , the $/HP ratio is better...............the rest is definitely very cool,I like it too........ but farther down the slippery slope, cost no object path.
regards,
al
al lkosmal 05-03-2016 06:51 PM
You will love it.
what pistons did you use to get to 9.8:1 by shimming....10.5:1 JEs?
al lkosmal 05-05-2016 09:37 PM
http://forums.pelicanparts.com/uploa...1462513036.jpg
lvporschepilot 05-06-2016 07:04 AM
A single plug ITB 2.7 engine with these cams (and 38-39mm intake ports, and 46mm ITBs) should be solid for around 220 at the wheels or 245-250 crank. Great builds
prebordao 05-06-2016 07:11 AM
Al, what's the size of the Speed triple ITB's ? I can't recall...
Trackrash 05-06-2016 09:09 AM
Who is doing all the case work?
I would love to see all the details.
al lkosmal 05-16-2016 07:30 AM
Sorry for the delay......I got sidetracked with commitments on customer engines....but I am back on it today.
The Speed Triple ITBs are tapered. 43.5mm at the top, tapered down to approx 40mm (slightly ovaled) at the bottom.
regards,
al
