Bill (guest)
Guest
Posts: n/a
Nick - Sorry; connector I was asking about was on a 1988 911 coupe. Had some sort of guide sticking up through the middle that I thought held it on, but gave a a few back-and-forth pries with a trim tool and it finally came off. One other question, though: when I got the motor and regulator out of the door, the window rail came loose from the window. It was badly rusted, so I'm replacing it. Is there any form of adhesive used to hold it to the bottom of the window, or does the window just jam into it with the rubber strip along the bottom of the window? Do you guys sell that rubber strip as well as the rail? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 05-06-2016, 01:00 PM
Nick at Pelican Parts's Avatar
Good question, if the clamp bolts tight, no adhesive is needed.
I'm sure we can get you the rubber strip.
- Nick
