Bob Gruen's Avatar
Rubber clutch line on an '87
So the small rubber hydraulic line to the clutch slave cylinder has developed a leak and will be replaced. Problem is I am not sure if it is supposed to be above or below the main shaft of the throttle bell crank lever. It is currently above the bell crank, resting on it and rubbing against it, which must be wrong and may have contributed to the leak. It seems to want to occupy the same space as the bell crank, so the line on the master cylinder side must not be quite right.
So does the hydraulic line go above the throttle bell crank lever, or below it?
Bob
Old 05-06-2016, 02:41 PM
prschmn's Avatar
Should be above it. The hard line out of the tunnel probably got tweaked---just "retweak" it
a bit and you'll be fine
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-08-2016, 04:12 PM
