spark plug for 911 3.0SC ROW
hi
new topic for a subject discussed plenty of times ....
I agree, but I'de done some search and it's not quite easy for me to find an answer between US or ROW spec and past offer and present offer
regarding the posts
BPPR7ES seems the standard best solution
it seems the BPR8ES is more for the 1980-1983 Euro spec
regarding NGK answer, I find some posts were they gives the B9EVX ref (does not exist)
now, on the NGK UK website, they only gives the B8EGV or BR8EIX (upgrade) ref
no more copper ref
so price is from 1 to 4 times the copper price
to be honest, I can survive ...
but I did not find any logical explanation or good reason to choose those ones apart of spending more with NGK
choosing the BPR8ES for a Euro spec 3.0SC is ok ?
thanks a lot for your help
Old 05-08-2016, 10:41 AM
wolds's Avatar
Bosch W 260 T 2 is what is in the RoW owners manual which equates to NGK BP9ES. I'm running this plug without issue.
Lorraine 83 SC CAB RoW
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 05-08-2016, 01:43 PM
Reiver
Reiver's Avatar
This.....run the NGK 9's....you want the coolest plug that will work and this is what Porsche calls for....high compression one plug so......
I'm running the same one NGK BPR9ES
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-08-2016, 02:31 PM
That is a really cold plug, what compression are you running?
I've been using the BPR7EIX
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-08-2016, 02:57 PM
wolds's Avatar
Both Reiver and I are running 9.8/1. The RoW cars run one range cooler plug then US cars.
2003 C4S coupe
07 BMW R1200RT
76 BMW R90S
76 BMW R60/6
Old 05-08-2016, 04:01 PM
Reiver
Reiver's Avatar
2 range cooler...US uses the NGK7 series ROW 930-10 the NGK 9...this is from the Porsche Service Manual when you cross check the Bosch plugs listed with the NGK's.
The compression dif I suspect.
De Oppresso Liber
Old 05-08-2016, 07:40 PM
Wer bremst verliert
JohnJL's Avatar
Originally Posted by florent78 View Post
hi
regarding the posts
no more copper ref
You dont list a location, use or any mods for your car, those can all make a difference.
BPR8 are quite 'cold," I run those in a boosted 911, but BPR6 in the NA cars.
Give more details about the car, as well as why you are changing?
Oh, E3 and multi-platinum points are a waste.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-08-2016, 08:01 PM
Reiver
Reiver's Avatar
send me your email in a private message and I'll send you the 81-83 ROW spec manual in PDF.
You can check for yourself what plugs you need....the NGK9's.....or equivalent to that heat range.
De Oppresso Liber
Old 05-09-2016, 08:31 AM
awjens's Avatar
Send a message via AIM to awjens
Can you send me that in a PM also?
Old 05-09-2016, 06:57 PM
hi guys
get a discussion with a technician from NGK
he confirms me I should use the BR8EIX plugs
he confirms me due to different compression and fuel in US, plugs are different.
for Europe, Porsche used to install platine plugs originaly.
platine is not in use with NGK and they consider Iridium corresponds to the original platine plugs.
that's the reason I cannot find copper plug for my car on NGK Europe website
saying that, it does not mean copper plugs will not work.
I just give you the explanation from the technician.
he confirms me too the BR8EIX are "cold" enough
just buy the plugs, I will see
thanks for your answers
Old 05-09-2016, 11:49 PM
