Scott S's Avatar
Period Correct Stereo install Question
Hi All -
I bought a period correct Blaupunkt Bonn for my 77 that has been reworked to accept MP3input. Works great.
I am not 100% happy with the install however. Even with the correct clips and rear bracket, the case is not as tight in the dash as I would like. Per the pic below, I am using the Blaupunkt face place.
Should I be using the factory Porsche recessed face plate pictured below? Will this snug things up and is this the way it would have been installed (correctly) back in the day? I really want it to look as stock/original as possible.
Thanks -
Scott S
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 05-09-2016, 01:33 PM
Do you have the rear support bracket?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-09-2016, 01:34 PM
definaltly need the rear support bracket. If that dosent improve it to your desire, then the recessed plate will fit better (slightly larger than your existing plate).
Old 05-09-2016, 01:44 PM
Scott S's Avatar
Yep. It is very solid front to back. The clips keep it pretty solid left to right. It is the up and down where I can move it easier than I think it should. Dash is stock (not cut up or anything).
Thanks!
Scott S
