Metal Guru
911nut's Avatar
Bumper Extension Support Removal
While I'm pulling my suspension apart and plating/painting everything I'd like to attack the bumper extension supports that are immediately behind the rear wheels. At the bottom ,the supports are attached to the extension with a nut and bolt. At the top they disappear into the engine compartment side rail so it's not easy yo see how they are attached. Are they screwed into a weld nut?
Thanks.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 12-19-2002, 05:29 AM
GB83SC's Avatar
The rear bumper extensions are held at the top by 4-8MM screws the ones on the right hand side are a little tight due to the oil severve tank but you can get to them with a screwdriver handle with a 8MM socket. Look with a flashlight to locate the bolts.
Its very easy!
Good luck.
George
My Owners Gallery Page
1983 911SC - Built July 1983 #2547 out of a total 2559 shiped to the US. in 1983. Could be the last U.S. production SC still running.
1995 BMW 525I
2001 Highlander- kid mover
Old 12-19-2002, 05:50 AM
Also, the rubber bellow is attached to the bumper extension will need to be removed as well. not the easiest job to do, but you'll manage. 8mm nuts/bolts, if I remember correctly.
Old 12-19-2002, 08:13 AM
Metal Guru
911nut's Avatar
I'm not looking to remove the extension, just the supports.
Anyone?
Paul B.
'91 964 3.3 Turbo
Old 12-19-2002, 09:06 AM
