Need trans help
Driving along normal, popped out of second, (never done this, good 915 out of an 82sc)put it in third and Kaplooie. Moving slow when it happened, maybe not to much damage??. Part of a syc. and some dog teeth fell out from the lower cover. Pulled the rear cover off and found the big nut laying as you see it. Not a trans guy, not sure what to do, esp. after reading the 9 part tut. John, can I send it to you? Or someone in the Memphis area?http://forums.pelicanparts.com/uploa...1462914347.jpg
http://forums.pelicanparts.com/uploa...1462914429.jpg |
Is this a trick question?
That thing needs a rebuild. |
Don,
I have a guy in the Southhaven area who just rebuilt my transmission. |
well hook a brotha up man. You must be happy with his work to recommend him.
Don... Hopefully you lucked out by paying attention and stopping sooner rather than later.
I had to stop at once. Coasted to a stop along a straight stretch of hwy 10 miles from home. Towed it home behind my truck with a tow strap. I see no damage to any big gears, just a lot of little parts.
I'm still trying to figure out what that crud is on the teeth in the first picture.
saw dust and spider webs Matt. It kinda got tossed to the corner of the shop.
That's what it looked like, I just wasn't sure why it was inside your gearbox. :)
I have owned this trans many yrs, it has never been apart as far as I can tell. I read in P Zimermans tutorial that the nut being loose is common.
| All times are GMT -8. The time now is 10:14 PM. |
