low pressure regulator
Called shop and explained that sometimes at a low rpm, w/ steady foot on the gas, the car is "bucking", like I'm quickly pumping throttle. They told me it sounds like my low pressure regulator. That an easy DIY to replace??
'84 Targa: Duel output muffler, cat bypass, performance chip, cup airbox, P-Short throw, Euro H4s, Bilstein HDs, lowered torsion bars, strut tower brace, t-tie rod ends, etc.
Old 05-20-2016, 10:15 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Well, to determine that, I would get a Fuel Gauge place it on the Test port of the driver side fuel rail to get he readings per Bentley.
Yes, it is a DIY but a real PITA break that mounting nut, a partial drop is recommended or while you have the engine out is best.
Question, do you have a stock chip? If so that is a characteristic of a stock chip or the AFM potentiometer strip worn down.
'85 Carrera Targa
PCA/POC
Old 05-20-2016, 10:35 AM
this sound beyond my type of DIY! haha It rarely happens, so ill just wait till my next service. Chip wise, no I have one I bought from fabspeed and installed it years ago.
Old 05-24-2016, 05:35 AM
