Output flange bolts
Read every thread here and hoping for a little clarification. I can only find one flange bolt here on pelican and does not indicate as being a stretch bolt. The pet for an SC says it should be stretch.
Will this one work in any case regardless of whats installed now? I did see somewhere that the stretch bolt had been superceded.
Hex Screw 10x75 90133227512 - Genuine Porsche | Pelican Parts
Just trying to gather all the info so I only have to order once.
1982 911 Targa, 3.0L ROW with Webers
Old 05-23-2016, 08:44 PM
Send a message via Skype™ to Porboynz
Looks correct to me, the stretch bolts usually have a reduced shank between head and thread. I have not heard that its been superseded but as long as it is torqued correctly should be good. I reused that bolt when replacing the seal, cheapskate.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-23-2016, 10:41 PM
