sbmackie's Avatar
getting at master cylinder
Hello,
As my tech likes to say "Stand back! Scott's got a tool in his hand!"
So I've got blue stains under my master cylinder housing. I'm pulling it up. I don't have a skinny enough wrench to fit on the right front nut as you look at the car from the front. Can I remove the larger side facing nut that's blocking my access? It's the one on the right of picture 2.
Even more basic, if I pull this housing, will I be able to see the master cylinder?
Scott
I ain't so smart
Old 05-11-2016, 10:40 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yes, you can and must to get to that nut.
Just take good notes on orientation.
'85 Carrera Targa
PCA/POC
Old 05-11-2016, 10:50 AM
sbmackie's Avatar
Ok
Back to the garage. Wish me luck.
Old 05-11-2016, 10:55 AM
That Guy
Techno Duck's Avatar
That bolt screws into a support that connects to the pedal cluster so it's no issue to remove. If you have trouble screwing the bolt back in pop off that lower plastic cover and you can move that support with your finger if needed.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 05-11-2016, 11:39 AM
emac's Avatar
You also have to disconnect the brake pedal inside the car and there is a nut under the dash that has to come off before the MC can be removed
Ernie
Old 05-11-2016, 03:58 PM
Scott a crows foot might get that nut off. Sounds like you have to remove the big nut to get the assembly out anyway.
Old 05-12-2016, 05:24 PM
i just helped by brother take his off. I have to laugh at this as I just replaced both the master cylinder and the booster in my s10 blazer.. I can say they need to shoot the guy that came up with the way it's installed. What a pain in the ASS>
Old 05-12-2016, 06:30 PM
i replaced my mc with the booster and everything in place. certainly seemed easier that way
Old 05-12-2016, 06:36 PM
