1973 heat exchangers help
Hi, I'm in the process of fixing an oil leak on my 911, i noticed one of my heat exchangers outer shell for the heater is loose is there a way to fix that or a restoration process I can do?
Old 06-03-2016, 10:15 AM
Remove the heat exchanger and you will see the issues. On the rear tube close to the flange their is a tab that connects the shell to the tube, it often breakers. The area where the three small tubes enter the shell is often rusted and loose.
Old 06-03-2016, 11:08 AM
I just weld them up with my MIG [wirefeed welder] welder. You usually don'y have to take them off. I have been patching the heat exchangers on my 1973 for 17 years.
If you don't weld maybe you have a friend that can do it.
As long as the inner headers are sound you can patch up the outer housing and brackets etc..
Sure you can replace them, but stainless is the way to go but $$$ and you may have some frozen studs to deal with.
I have just had good success with repairing them. I am not in the rust belt so I don't have to deal with any corrosion.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-03-2016, 11:36 AM
Get some SSI's those rusty HE's can kill you.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-03-2016, 11:42 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Post a pic. Where in Socal are you? Maybe one of us Socali's can take a look???
One of mine were loose do to a scuff from PO driving over something. I used JB Weld and aluminum foil. It held together for over 4 years. Buddy donated one of his old good ones, swapped it out. I think I will take a my flux welder to the old one and fix it right .
'85 Carrera Targa
PCA/POC
Old 06-03-2016, 12:02 PM
