rennline pedal set adjustment tips (3.2)
Hi guys. I have my aluminum rennline rev 2 pedal set in place. Nice piece of kit.
(edited to make sense) I am doing some fine tuning of the linkages, but my biggest issue is that I want the gas to be at the same level, or just below the level of the brake pedal when it (the brake) is fully depressed. Right now the gas pedal sits proud to the engaged brake pedal and the aluminum floorboard prevents it from going as low as I would like. I could hack off the top adjustable mount from the back of the gas pedal, but I was wondering if others had more elegant solutions. Thanks for any tips.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 10-08-2014 at 05:16 PM.. |
Hmmm, I think I would first adjust the pedal for WOT and then go from there. Are the pedal "top plates" adjusted all the way down?
Todd
'81 SC |
I think I see visualize you are talking about.
This is where I have it now. ![]() I want the pedal to sit deeper, but as I move it back, the "W" shaped mounting bracket then interferes with my aluminum pedal board and prevents WOT. Only solution I can see would be to hack it off. If I move the "W"bracket down a notch, the pedal frame taper around the throttle linkage interferes with it going any deeper than I have in the photo above. I think I have WOT set properly, but I will do a search to make sure I did. Also, while I have your attention, did you have problems fastening the clutch bumper to the aluminum floor-pate? I think I need to add a few washers in as it seems too thin to get a good bite with the oem mounting hardware/fasteners.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 10-08-2014 at 06:24 PM.. |
Maybe need to adjust the throttle rod so the pedal "base" goes deeper, then adjust the pedal face so the "W" sits higher. Definitely fine adjustments are needed. I need to shorten my pedal rod a bit more as I'm bottoming out on the linkage.
I don't have the floor boards (yet). Todd
'81 SC |
Caveman Hammer Mechanic
Clearance the floorboard so the stop is the limiter.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
83 911 Production Cab #10
Which finish did you get, Perforated or Rubber Grip?
I'm just about to pull the trigger but can't make-up my mind but leaning toward Perforated which has a raise grip.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
JJ,
Rennlist is currently having a 15% off sale if you order directly from their web site. Use code 1225, valid until dec 25th
Hugo |
Yeah, that is where I'm getting it. At least it cancel the exchange rate ![]() ![]() ![]() Merci JJ
rennline 15% off
guys is 15% off on the boards and everything..? it seems like only
on selected items.. thanks, harry Happy Holidays to All..! |
Get rubber grip, you can just pop them out if you want perforated.
Todd
'81 SC |
I got it on the adjustable 4 pedals set, on the solid floor board but not on the drilled floor board!!!
Thanks for the validation.
Not Royce
the best thing i found that works well for foot grip is if you apply skateboard board tape, works much better than the rubber grip. since rubber grip would actually slip if your shoes/pedals are wet
Pistache: 1984 911 backdate @RWB_Royze on IG www.instagram.com/rwb_royze RWB Japan/Middle-East representative |
I too went with the non-perforated rennline floorboard. I figured the weight savings were not worth the grime that would build up back there as I keep it visible in my car. I don't want any risk of carpets binding things given my past sticking accelerator issues.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Pelican Parts Vendor
It work out OK because I had a $20 Appreciation coupon from PP and the drill board put over the threshold. Can't wait to install the whole kit. ![]() Thanks for following up.
RL Black Friday sale is on now...
I want track mats...
I just got two mats in black, a jack plate (I want two), and a fire extinguisher mount for under my seat.
