Newbie MK Muffler Install - How'd I do?
Have you done a compression test on that engine? You may want to do one.
The muffler install looks fine but if that's a stock motor with stock cam somethings sounds off. |
sounds like mine with lots and lots of vacuum leaks including a cracked airbox.
It sound like that on first start but not during driving. Less "bubbly". It runs strong. You guys are freaking me out. Could the install cause damage? It was an easy straight swap.
Is this a 3.0L SC? I'm sure others will chime in. |
+1 lean / miss Sounds like a dragster motor. Check all your plug connections first.
After I drive it, it idles normal. Just at startup. Will post another video soon
here it is after short drive. https://youtu.be/ih64NFCgrzM
Yeah sounds much better. Any butt dyno improvement? Really interested in getting the same muffler.
| All times are GMT -8. The time now is 03:19 AM. |
