Newbie MK Muffler Install - How'd I do?
Anything to look for that might suggest I goofed? Thx! Great sound
https://youtu.be/7jLnd07dQ4E
Old 05-20-2016, 11:18 AM
scarceller's Avatar
Have you done a compression test on that engine? You may want to do one.
The muffler install looks fine but if that's a stock motor with stock cam somethings sounds off.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 05-20-2016, 12:22 PM
New-ish 911SC Targa Owner
pampadori's Avatar
sounds like mine with lots and lots of vacuum leaks including a cracked airbox.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 05-20-2016, 12:34 PM
It sound like that on first start but not during driving. Less "bubbly". It runs strong. You guys are freaking me out. Could the install cause damage? It was an easy straight swap.
Old 05-20-2016, 01:16 PM
scarceller's Avatar
No damage by the muffler install. Just sounds like a mis-fire or exhaust valve slight leak? It may be just running a bit lean? When you open up the exhaust as you did you can really hear things a lot more than with the stock muffler. Just suggesting you check things out, that burble you hear at idle is not normal on a stock motor.
Is this a 3.0L SC?
I'm sure others will chime in.
Sal
1964 356SC (SOLD)
Old 05-20-2016, 01:20 PM
Registered Minimalist
75 911s's Avatar
+1 lean / miss Sounds like a dragster motor. Check all your plug connections first.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 05-20-2016, 01:27 PM
After I drive it, it idles normal. Just at startup. Will post another video soon
Old 05-20-2016, 01:46 PM
scarceller's Avatar
Just have your air fuel mixture checked, but if after it warms up if it goes away I suspect lean at cold start. Common problem in the SC cars is cold start and the warm up regulator.
Sal
1964 356SC (SOLD)
Old 05-20-2016, 01:50 PM
here it is after short drive. https://youtu.be/ih64NFCgrzM
Old 05-20-2016, 02:11 PM
75 911s's Avatar
Yeah sounds much better. Any butt dyno improvement? Really interested in getting the same muffler.
Old 05-20-2016, 03:09 PM
