Footwell blower
Hi
I have an 1986 Porsche 911
I know there is five fans in this car..
So far I have tested by using the battery power to check all five fans and it works fine. Except I had to repair the auto heater blower switch the one control the engine heater blower..does Off and On
only three heater blowers work except right and left side foot well blower..
Question is does is have the relay? which of the switch that the turn on those foot well blower
have not yet check the heater fuse,,the is my next step ..thanks
Old 05-20-2016, 03:06 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Footwell blowers.
Originally Posted by frankoporsche View Post
Hi
Here is the heater relay located in the engine compartment-Driver's side.
Here are a few "Hints).
In order for the foot well blowers to work, the engine compartment
heater motor must be on.
Also a possible concern.
Good luck,
Gerry
pm me as needed
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-20-2016, 03:31 PM
Heater relay location.
Relay & Location.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-20-2016, 03:40 PM
Question
Auto heat control regulate footwell heater motor speed?
Old 05-20-2016, 03:45 PM
Switch.
Question
No,
The foot well blower speeds are controlled by the console mounted rotary switch.
Here.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-20-2016, 03:54 PM
Okay
here is what I got so far,,every things I tested did passed...no failure
what is next?
I plugged the relay back in and turn the key on engine at start mode and lift the red level up for rear blower motor to come on ..and rotate the rotary switches control the footwell still is not working
well there was something I am not sure if this is right..When I jump the wire from the pin 3 and 4 together, the footwell motor was running at slow speed on position zero .than I rotate to position 2 the same speed,position med ,it got faster and rotate max even faster .is the Okay
Old 05-20-2016, 05:19 PM
Okay
what is next?
I plugged the relay back in and turn the key on engine at start mode and lift the red level up for rear blower motor to come on ..the footwell not working
Need Footwell Blower Assistance
Have a look at this thread.
Also, shorting pins 3&4 bypasses the relay.
You need to find out why that relay is not engaging.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-20-2016, 06:19 PM
As per my post, I don't recommend this,
or, shorting pins 3&4.
It would appear that you are missing the
ground to pin #2, or 12v to pins 5-6-7, or 8.
The 12V to the Reed switch coil next to the relay
(right side), activates the Reed switch,
as shown in the pics I sent.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-20-2016, 06:31 PM
there is a guy Porsche owner have the problem as mine
his login names "Ramp"
Old 05-20-2016, 07:28 PM
Auto heater control switches
Hey Gerry
I did some more tested .... I disconnect the autoheat control plug from engine bay harness and I power up 12 volt to auto switches ,the footwell motor came on...
I have two switches ,what are they and do?
I connect the 12 volt to the wires ,white/blck trim and black ( white switches) and the footwell motor works
I double check
The funny part is ..I bridge the wire to pin 3 and 4 the auto switches works ,I was able to change the footwell motor speed
PS I did bypass the relay no change
Old 05-20-2016, 08:05 PM
Wiring.
Shorting pin #'s 3&4 bypasses the relay.
Shorting the black/black white wires bypasses the rotary switch.
Contact "Ramp" & see how he did.
G.
1986 911 Targa.
Only in L.A.:
Old 05-21-2016, 10:13 AM
G.
Hi
By doing this what Ramp did ..does is eliminated the motor speed on rotate dial switches?
Old 05-26-2016, 01:46 PM
Ramp posted this from the beginning #1 ( Pin 9 to Pin 7 = 12v with levers up. Levers down actually had .07v, not fully zero)
afterward #2 (Pin 9 to Pin 7 = HAS 12V REGARDLESS OF LEVER POSITION)
Now I am confused..so far item one is what I have now..
Old 05-26-2016, 01:49 PM
pm sent.
1986 911 Targa.
Only in L.A.:
Old 05-26-2016, 02:25 PM
Thanks Guy......
I found the problem ..it was the heater relay...you have to open up inside the relay and see if any bad solder or contact point...between the pin#3 and 4
Old 05-26-2016, 02:47 PM
