-   -   New VR. Still 14.9V at Idle. WTF?? (http://forums.pelicanparts.com/porsche-911-technical-forum/916315-new-vr-still-14-9v-idle-wtf.html)
CCM911 05-31-2016 04:54 AM
I was putting out too much voltage to my battery, so I replaced the voltage regulator. Yet I am now still putting out 14.9 volts terminal to terminal at idle.
Do I need a new alternator?
Am I missing some other check?
I am clueless on this(amongst many other things).
30westrob 05-31-2016 07:46 PM
Do you have a chargeing light on? A bad diode in the alternator can cause over voltage.
Noah930 05-31-2016 08:22 PM
What happens to the voltage when you start driving the car (and increase engine revs)?
CCM911 06-01-2016 06:37 AM
I will check at different rev ranges. I was by myself, so was unable to check the range.
No light on the dash.
WIth a bad diode, could it still overcharge, even with a new voltage regulator?
30westrob 06-01-2016 02:29 PM
Yes. I had a glowing charging light with over voltage on my 73 Targa. Replaced voltage regulator, with no change. I then pulled alternator and found a bad diode. After diode replacement all functions returned to normal.
