New VR. Still 14.9V at Idle. WTF??
I was putting out too much voltage to my battery, so I replaced the voltage regulator. Yet I am now still putting out 14.9 volts terminal to terminal at idle.
Do I need a new alternator?
Am I missing some other check?
I am clueless on this(amongst many other things).
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 05-31-2016, 04:54 AM
Do you have a chargeing light on? A bad diode in the alternator can cause over voltage.
Old 05-31-2016, 07:46 PM
Driver
Noah930's Avatar
What happens to the voltage when you start driving the car (and increase engine revs)?
1990 Black 964 C2 Targa
Old 05-31-2016, 08:22 PM
I will check at different rev ranges. I was by myself, so was unable to check the range.
No light on the dash.
WIth a bad diode, could it still overcharge, even with a new voltage regulator?
Old 06-01-2016, 06:37 AM
Yes. I had a glowing charging light with over voltage on my 73 Targa. Replaced voltage regulator, with no change. I then pulled alternator and found a bad diode. After diode replacement all functions returned to normal.
Old 06-01-2016, 02:29 PM
