Euromeister coating ?
I am thinking of buying a set of Euromeisters from our host and I would like a satin finish on the petals . What coating do they come with ? Anodized , Clearcoat or nothing ?
Thanks , Scott . |
The centers are painted, the outer rim is machined aluminum.
Member 911 Anonymous
Machined aluminum is not smooth, it is grooved so be prepared.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Rescuer of old cars
And clear coated as well.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Thanks guys , I was worried that the centers were powder coated or they had some kind of coating that is hard to remove . I'll post some pics when I refinish them .
Scot 78 911SC coupe, sold,, 2019 Macan S "my friends all drive Porsches, I must make amends.." |
I stripped and refinished a set of Euromeisters and let me tell you that clear coat was tough to get off! Use the strongest paint stripper you can find.
The results turned out nice though. ![]() ![]()
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
I refinished a set a while back. I had a pair of genuine Fuch 7" fronts and bought the 9" Euromeister rears. The machined outer rims didn't match the smooth front rims. I wasn't after a polished look so I ended up bead blasting the the rims on both pairs of wheels. The bead blasting removed the machined grooves and clearcoat on the Euros. I repainted the centers satin black and clear coated the raw aluminum. Turned out pretty good. The Euromeisters were noticeably heavier than the real Fuchs, but that's to be expected for a cast versus forged wheel. Overall I was pleased. The Euromeisters are a nice low cost alternative for expensive 16x9 Fuchs.
