911 3.2 stock DME chip
Hello,
I got my 911 Targa, 1988 USA model, installed with a high performance DME chip. On hot weather the motor sometimes misfires. Using Euro 98 (I live in Spain) mainly resolved the problem, but not completely. So I think the best way is to re-install the original DME chip. But unfortunately I don't have it. Does somebody want to sell his original DME chip? The chip should be labeled #1267355358. Thanks, Gerber |
Member 911 Anonymous
Try the Used Parts Section and type WTB.
You really should check you AFR ( Air Fuel Mixture ) to see why it is missing. Stock chip may just do the same thing if AFR is off.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
+1 on stock doing same perhaps
I had an issue that was similar and more disastrous -- car wouldn't start etc. Replaced SW chip with known good stock chip = no better my case it was CHT sensor |
Thanks for your replies. I will put a message at the Used Parts Section as well. The DMR switch position is at #4, so I undrstood that AFR is switched on.
user SCARCELLER in the forum can make you one.
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
If it's a 28 pin chip I can cut you a 89 chip, if it's a 24 pin I can help but you'd need to send the DME to me to have it converted to 28 pin.
But I agree with prior post, check your base mixture. Who's chip do you currently have?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
If it's a 358 chip, it's a 28pin 8K chip, I can create that chip for you. PM me if you need it.
Currently the DME has a Weltmeister 28 pin chip.
