Vaccinated and Boosted
Electrical Gremlin
![]() ![]() ![]() First off this problem is in my E30 BMW vert. My gage cluster fuse keeps blowing. I believe I have located the terminal block where these wires all connect. My question is how do I find the wire or wires that are causing the fuse to blow? Any tips? Anything??? Thanks!!! mg
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
Member 911 Anonymous
Honestly, we probably will not have a clue, but my guess would be to pull out the DVM and do a resistance test on all wiring to the cluster to find the culprit.
Did you do any modifications or changes prior to this event?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I did change the antilock brake relay. The antilock light was on and this is a common problem. The light is now off......but I wonder.....perhaps I need to look here first.
I would, you never know.
Fleabit peanut monkey
Where in Ohio?
1981 911SC Targa Last edited by Bob Kontak; 06-08-2016 at 03:14 PM.. |
Well I just checked the new relay with a mm and determined it was not responding like my bad relay. I then took my old relay apart and corrosion between the points, cleaned the points and reinstalled. All good now!!! So beware of potential faulty new relays!!
Thanks for the help! Mg
