Engine builders, looking for product advice.
Hello--
It's been a while since I built an aircooled engine. What brand case sealers and assembly lubes are considered the "state of the art" these days? Also, other then elbow-grease, is there a cleaner that removes Permatex case sealer? Thanks, --Papermaker |
Schleprock
The Complete Engine Sealant Thread...
Permatex's gasket remover spray used to work really good on the orange case sealant (Loctite 574) but the next generation low VOC formula kinda sucks & is much weaker. I've had good luck with using Loctite Chisel remover solvent.
Kevin L '86 Carrera "Larry" |
Thanks for the thread KTL.
--Papermaker |
