Shifter
Hey guys does anyone know what compound is used to hold the shifter in place?
Old 06-11-2016, 07:58 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The knob or the shifter stick?
If original, it is held on by a crush sleeve. You have to use a open box wrench, a mallet and firmly hit up on it and it will pop off, then you will see the oem crush sleeve.
If epoxied, that is another story.
'85 Carrera Targa
PCA/POC
Old 06-11-2016, 10:16 AM
Taking it apart is easy
Jerome74911S's Avatar
Yes, the direction you are going with this is unclear. Do you want the knob on or off, or otherwise what do you mean by the 'shifter'?
The crush sleeve that held the knob on needs to be replaced when you reinstall the knob, but aftermarket ones do not hold as well as the original. I would not epoxy it on, though.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 06-11-2016, 01:04 PM
joefrantz's Avatar
The shifter is held in the base fitting by some sort of cement. Probably epoxy. It easily removed by applying heat. I used a hand held map gas torch and it came loose in about 15 seconds. Some people tack weld them, but if you ever want to get it back out (I've tried a number of different shifter lengths) JB Weld or a similar 2-part works fine.
Joe Frantz
73 911 T
Old 06-11-2016, 04:53 PM
I tack welded mine. I am not going to trust any glue here. It already broke once when quite new!!! I have never figured out why the factory glued them.
Not sure why you would not weld it. You can still change the length anytime if it is welded.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-11-2016, 06:00 PM
No the actual shifter rod ...Ive manage to remove it ..and was definitely bonded in with something but now it's been removed it's all loose in the coupler and swivels around..not ideal to be driving with haha
Old 06-11-2016, 06:04 PM
same thing happened to me. Tack weld it with a MIG.
03 Boxster
Old 06-11-2016, 06:07 PM
