3.6 conversion problems
Hi everyone-
Fired up the 3.6 today...sort of. Engine hits, then quits immediately. This is reproducable time after time. You can keep the starter engaged and mess with the throttle, engine snorts, pops, acts like its out of time...any help is greatly appreciated-
Bill
Old 12-22-2002, 06:26 PM
Moses's Avatar
On my 3.0 the same problem was a fuse to lambda sensor. Sounds like a fuel/timing/computer problem to me.
Old 12-22-2002, 07:10 PM
Kevin Stewart's Avatar
did you do the up date on the distributor?, sounds like timming or a gas problem, which fuel pump did you use, Kevin
Old 12-22-2002, 09:04 PM
RETIRED
Joe Bob's Avatar
Check it all.....fuel PRESSURE, timing and spark.....
Old 12-22-2002, 09:49 PM
