Slow down the 915
My 85 is old like many and I do all the tricks to get it in first gear. But I also just noticed that if I put the box in neutral about a 100 yards before a stop sign or a light , it slides right into first. My question is would a thicker gear box oil help slow the gears down faster? So my 911, when the engine and trans are both moving slow, it pops right into gear. If you have a higher mileage car like mine, try it.
Peter Zimmerman* recommends a similar technique in that you snick it into 1st just before the car comes to a stop. Worked great when my '84 synchros were worn. With new synchros (April) it goes right in even nicer. The 915 must be fully understood and respected in what it can and cannot do in order for one to appreciate and enjoy it.
*The Used 911 Story
'84 Carrera Cabriolet |
Member 911 Anonymous
To insure it will pop in "slow/stop" the gear by touching 2nd before plopping into 1st.
As far as thicker oil, it will not do much IMHO. Just practice the touching of a higher gear before dropping into 1st at LOW SPEEDS, like under 10MPH or even less or you will lose couple or several dog teeth. BTW, do you have 75W90 or 80W90 in her now?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Under the radar
Thicker weight oil will likely make it worse.
The 915s really don't want to go into 1st if you are moving at more than 5-10mph. If you want to extend the life of your 1st gear synchro you can wait till stopped or almost stopped, double clutch, or touch 2nd before going to 1st.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-03-2016 at 12:06 PM.. |
Touching 2nd has always worked wonders for me, but I never understood exactly why. Is the mainshaft still spinning a bit, even with the clutch depressed, then touching 2nd synchros spins the cluster a bit to match the mainshaft rotation??
Short of that, I can't figure out what exactly touching 2nd does.
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
Best way to go into a lower gear is double clutching. If done right synchros would not be needed.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Yep, pop taught me that in the Austin-Healey. Prolongs the life of the synchros too.
Location: behind the redwood curtain, (humboldt county) california
+1
Under the radar
Worn synchros were undoubtedly an epidemic on British stuff back then the same way worn 915s are today. My dad's '67 Healey didn't have a synchro on 1st. It would go into 1st at a very slow roll without any protest, however. 915 reminds me a lot of the Healey box.
Under the radar
A properly rebuilt 915 should last a long time. The advantage of the Healey trans was the shifter came directly out of the trans. No shifter bushings or couplings like the 915. Back to our normally scheduled program.......
Jim, I have Swepco 212 in the 915 now. Recommended on this site years ago. By Early S man.
