-   -   Where to Test Oxygen Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/918925-where-test-oxygen-sensor.html)
kyngfish 06-20-2016 02:48 PM
Hi All, I've been poring through old threads trying to find a picture of where to test the oxygen sensor. I have a Fluke Digital Multimeter ready to go.
I need to connect the positive to the signal wire, and the negative to the ground, while the engine is hot to test the sensor. That much I know. The only thing is, where is the sensor wire and which is the signal wire?
Thanks!
86 911 Targa 06-20-2016 03:25 PM
Thanks!
I believe that pins 2&3 are the heater 1 is the signal wire to pin #24 of the DME.
Your voltages should fluctuate between .1-.9 VDC
http://forums.pelicanparts.com/uploa...1466461467.jpg
Good luck,
Gerry
kyngfish 06-20-2016 03:34 PM
Cool. Thought there was a way to test in the engine bay?
wrxnofx 06-20-2016 04:14 PM
You should get a Bentley manual...
http://forums.pelicanparts.com/uploa...1466464478.jpg
kyngfish 06-20-2016 06:27 PM
Lol
Between the fluke multimeter a wide band oxygen sensor and a Bentley manual I'll be spending nearly a thousand this week just on tools! Thanks for the photo. Care to tell which is the ground?
T77911S 06-21-2016 03:47 AM
it does not matter. just forget about the - or swap the leads if you don't want to see the - if you connect it backwords
kyngfish 06-21-2016 04:34 AM
(Thumbs Up)
kyngfish 06-21-2016 07:47 AM
This is going to sound like a really stupid question, but I'm REALLY new to all this. The Fluke has a setting for Volts DC or AC - I'm assuming that because the car uses a chemical battery, that the Alternator is also generating DC current and I should always test using the DC setting.
Correct?
DRACO A5OG 06-21-2016 08:35 AM
Dc.
kyngfish 06-21-2016 08:36 AM
Thanks!
DRACO A5OG 06-21-2016 08:40 AM
M,
In the pic above, you want to connect the Red lead from your DVM using alligator clips to post #1, on the connector going to the O2S and the Black lead to a good ground on the engine.
You want to do this when the engine is hot or at 194F aka Operating Temps.
At DC, note the voltage.
dicklague 06-22-2016 02:18 PM
I am trying to follow the math
Bentley $150 USD
Multimeter $5.00 to $50 for a good one.....Fluke $400 usd
Wide band o2 sensor $90 [but what do you need this for?
so I am up to $200 on the low side for stuff that works??
kyngfish 06-22-2016 02:29 PM
LM-2 Wide Band Oxygen Sensor 300
I have several things happening at once :)
Add CHT to the list
