Where to Test Oxygen Sensor
Hi All, I've been poring through old threads trying to find a picture of where to test the oxygen sensor. I have a Fluke Digital Multimeter ready to go.
I need to connect the positive to the signal wire, and the negative to the ground, while the engine is hot to test the sensor. That much I know. The only thing is, where is the sensor wire and which is the signal wire? Thanks!
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Your voltages should fluctuate between .1-.9 VDC ![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-22-2016 at 02:33 PM.. |
Cool. Thought there was a way to test in the engine bay?
You should get a Bentley manual...
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Lol
Between the fluke multimeter a wide band oxygen sensor and a Bentley manual I'll be spending nearly a thousand this week just on tools! Thanks for the photo. Care to tell which is the ground?
it does not matter. just forget about the - or swap the leads if you don't want to see the - if you connect it backwords
(Thumbs Up)
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 Last edited by kyngfish; 06-21-2016 at 07:46 AM.. |
This is going to sound like a really stupid question, but I'm REALLY new to all this. The Fluke has a setting for Volts DC or AC - I'm assuming that because the car uses a chemical battery, that the Alternator is also generating DC current and I should always test using the DC setting.
Correct?
Member 911 Anonymous
Dc.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks!
M,
In the pic above, you want to connect the Red lead from your DVM using alligator clips to post #1, on the connector going to the O2S and the Black lead to a good ground on the engine. You want to do this when the engine is hot or at 194F aka Operating Temps. At DC, note the voltage.
Bentley $150 USD Multimeter $5.00 to $50 for a good one.....Fluke $400 usd Wide band o2 sensor $90 [but what do you need this for? so I am up to $200 on the low side for stuff that works??
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
LM-2 Wide Band Oxygen Sensor 300
I have several things happening at once ![]() Add CHT to the list
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 Last edited by kyngfish; 06-22-2016 at 02:56 PM.. |
