Misfire after 20-30 minutes of driving. 2.8L
2.8L twin plug high compression engine with 46mmPMO carbs. Newly rebuilt with about 1000 miles on it. Ran fine the first 1000, then it started misfiring and losing power after driving for 20-50 minutes. I turn the engine off and open and close the fuel tank and it runs fine immediately. We have checked the venting and it was fine. The fuel pressure regulator is set at 3.5lbs. Will change the fuel pump next. Initially thought it was a vapor lock and then thought it was the fuel pressure. But hard to figure out since as soon as the car is turned off and back on, it is fine. Thanks ahead of time.
Welcome to the forum. I've found lots of help here.
Any "venting" or obvious pressurization of the fuel tank when you opened it? |
No. I even drove with the tank open to the air and covered with a cloth to make sure nothing could get in it, while keeping the tank protected. The engine actually started to misfire after just 2 miles.
ROW '78 911 Targa
Fuel filter(s) full of sediment?
I think Dennis is correct. You should have a filter for each carb. PMO sends 2 filters with new 46's.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I would rather be driving
Check fuel strainer sock in the tank for sediment. Of course, it goes without saying to check the fuel tank itself and make sure its clean.
What ignition system are you running? I would also check each plug carefully with a timing light to make sure it is firing on all cylinders. Is it possible that your ignition boxes or coils are overheating? Is dwell (if you are still running points) set correctly?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
How old is the fuel in your tank?
New-ish 911SC Targa Owner
Have you ruled out the CDI? I recall they fail after driving a while then come back to life after a short shut down.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Car started to misfire today as I was driving and luckily I was right next to a Porsche shop. Pulled right in and they felt it was electrical in nature as well, especially since it was perfectly fine after we turned the car off and restarted it. I have msd boxes. Will keep you posted. The other option may be the distributor cap?
What is your plug gap? It is common to open the plug gap with MSD and they can usually handle the extra current driving the larger gap. However, if you go too far, the internal coil drivers can overheat and start to thermally protect themselves.
Place your hand on the MSD box and coils to see if they are hot.
check your plug wires. make sure you don't have something shorting out. but if you have isolated it to fuel problems then maybe you need to check all fittings and connections. ...and as jamie said check the sock.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
