removing alternator
Is there a how to remove the alternator on a 72 911? could not find anything in search
The below can get you started.
One thing that was a speed bump for me was the cast fan shroud. It has a slot in it (at least on my 81) on the bottom. That slot fits onto a peg. Seems obvious, but if you are not aware you can perform way more wrestling and head scratching than you need to. If you are going to put in an alternator with an internal regulator you may have to do some carving up of the air diverter thingie on the "back" of the alternator to make it fit. Alternatively and more better, I think you can upgrade to a later diverter that fits the first year of the internal regulator SC. Maybe 82? Porsche 911 Alternator Troubleshooting and Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
| All times are GMT -8. The time now is 07:23 PM. |
