Anybody know the part # for the factory shims between ducktail and engine lid hinge?
I need the shims between the ducktail and the engine lid hinges. I think this pic is what I'm looking for but I could be wrong. Any help would be great, thanks Pelican.http://forums.pelicanparts.com/uploa...1467176717.jpg
You refer to a ducktail which would be an early car which would have used washers.
That part is from a 964 so you might look in the 964 PET if that specific parts is what you want. |
hinge shim
This is the closest I think but it is part no 99351246900 but fits earlier hinges.
http://forums.pelicanparts.com/uploa...1467215821.jpg |
that number doesn't show up, anyone else have a good number
Thanks Lorne M. |
I used washers when I fit the duck on my 83SC.
Found this on ebay.... |
I used washers from the store. I didn't even consider looking up OEM for something that costs .17 each.
Or use body shims (U-shaped) so you do not need to remove the bolt just loosen it.
993.512.469.00 is a good part number. Pelican shows it as special order from their Porsche dealer since they don't stock this part. $4.50 each.
You are looking for partnumber 999 025 098 02. Our host shows them as NLA but I do think they are available.
Thank you everybody, we are going to just make are own. Trying to avoid the stacked washer look on this build. Not that its bad but just wanting a cleaner look.SmileWavy
| All times are GMT -8. The time now is 12:30 AM. |
