LinkBack | Thread Tools | Rate Thread |
Anybody know the part # for the factory shims between ducktail and engine lid hinge?
I need the shims between the ducktail and the engine lid hinges. I think this pic is what I'm looking for but I could be wrong. Any help would be great, thanks Pelican.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) |
You refer to a ducktail which would be an early car which would have used washers.
That part is from a 964 so you might look in the 964 PET if that specific parts is what you want. |
86FlatSix
hinge shim
This is the closest I think but it is part no 99351246900 but fits earlier hinges.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
that number doesn't show up, anyone else have a good number
Thanks Lorne M.
83 SC |
I used washers when I fit the duck on my 83SC.
1983 SC - sold 2002 996 C4S - sold 1968 912 |
Found this on ebay....
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold) Last edited by nippy; 06-29-2016 at 02:57 PM.. |
Burnin' Rubber
I used washers from the store. I didn't even consider looking up OEM for something that costs .17 each.
Or use body shims (U-shaped) so you do not need to remove the bolt just loosen it.
Schleprock
993.512.469.00 is a good part number. Pelican shows it as special order from their Porsche dealer since they don't stock this part. $4.50 each.
Kevin L '86 Carrera "Larry" |
You are looking for partnumber 999 025 098 02. Our host shows them as NLA but I do think they are available.
Thank you everybody, we are going to just make are own. Trying to avoid the stacked washer look on this build. Not that its bad but just wanting a cleaner look.
