zenith fire hazard?
Just rebuild both zenith carbs on my 70 t. The air diffusers on the right side had all melted down like candle sticks! Apparently there had been a fire inside the top half, and the metal had melted down to the bottom and was just sitting on the top of those valves to the intake! Even the air box on top had melted down. Now here's the part that troubles me. Should I replace this air box or should I go with some K&N filters? I worry that the only reason the fire stayed inside the carbs was because of that airbox, but I really don't know. Any suggestions? Thanks.
Nick '70 911t |
I ran 6 individual foam 'sock' filters on my 2,2 T, but put the std airbox back after someone told me they tend to soak up fuel and ignite with dire consequences when the motor backfires through the carbs.
The foam filters also leaned out the mixture and took away low down power.
Steve in South Africa If it isn't sideways, it isn't fun |
soooo......stick with the stock air box then? I wish to avoid dire consequences.
for sale: '72 vette 454 4spd steel city grey '77 911s "black cherry" candy paint '77 911s targa yellow '91 integra ls special gsr swap |
