Chain Tensioner Oil Lines
Chain Tensioner oil Lines? is there a different line for cars with A/C the oil line to the chain cover does not allow the A/C bracket to be reinstalled?????
Old 07-03-2016, 12:12 PM
Discseven's Avatar
Rick... here's '79 930 cam line... then compressor over it mounted on standard bracket.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-03-2016, 12:42 PM
Old style a/c
The A/C on my 75 911S is the old style and it bolts to the top (4) studs on the chain cover above sheet metal lip and one rear intake stud also the plug on the top right inter fears with the reinstallation
Old 07-03-2016, 01:16 PM
That's the dealer installed aftermarket A/C
Bruce
Old 07-03-2016, 02:03 PM
If it doesn't clear, you have to make it fit by tweaking the line or modifying the a/c bracket.
206 637 4071
Old 07-03-2016, 02:39 PM
thank you for help
I modified the bracket all is good thanks again
Old 07-03-2016, 04:23 PM
