jbscheff's Avatar
Template Needed for Drilling Holes in a '73
I need to add the two holes in the luggage compartment for the brake reservoir hoses. I think they were inadvertently filled in during the extensive bodywork and rust repairs to my 1973 coupe. The area of concern is in the photo below.
I would like to get a photo and some rough measurements in relation to the hole for the wire harness and the sidewall. I can make a pretty good guess based on the location of the reservoir but some measurements would be better.
Thanks,
Jason
ps. if anyone can tell me how to make my photos appear right-side up I'd appreciate it. They are right side up in my photo library. The one on this post was even shot upright, but it still comes out sideways in the post. Sorry
Jason
'73 911 Carrera RS clone w/3.0
Old 07-02-2016, 11:10 PM
Discseven's Avatar
Jas... Don't know about brake res hoses. I have '79 - '80 / different config than '73. On photo... might be that Pelican system is rotating image because it's too long of a vertical image. Try to reduce height measure by reducing image size or cropping it. You can test with a new post and delete it afterwards. I know a 7" tall by 72 dpi vertical image works---post them regularly.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-03-2016, 02:16 AM
clarkd's Avatar
Grommet shown in your photo is located at the "valley" in the harness next to the one with the zip tie and red wire
Old 07-03-2016, 07:07 AM
jbscheff's Avatar
Clark, perfect, thanks!
Jason
Old 07-03-2016, 12:59 PM
