HPF-604 Fuel Pump
Hi,
I recently ordered a Fuel Pump from HIGHFLOWFUEL for my 1983 911SC, the problem i'm having are the electrical connections are not threaded ! Please check out the picture i've attached.
Thanks,
Rob
Old 07-06-2016, 08:44 PM
bump
Old 07-06-2016, 10:26 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I would get the mail connectors and splice onto the old wiring, it probably comes booted so it will help with road debris an corrosion.
Post your update please
'85 Carrera Targa
PCA/POC
Old 07-07-2016, 12:15 AM
Hi.
It came with ring connectors and two threaded nuts but I don't see how u can connect them without threads on the pump positive and negative sides.
Old 07-07-2016, 12:08 PM
E-85 sippin drunk
turbobrat930's Avatar
do the red and blue things pull off?
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 07-07-2016, 12:42 PM
RETIRED
Joe Bob's Avatar
Those colored ends twist off, the ring connectors slip over the terminals, then then screw back on. Common connection for electrical wiring.....
2012 ML350 3.0 Turbo Diesel
Old 07-07-2016, 12:59 PM
Awesome, I tried twisting them off by hand, I guess I'll have to use a small pair of channel locks lol !
Thanks !
Old 07-07-2016, 01:45 PM
