Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hmmmm could I do that during say a valve adjustment? Or do you have to take more of the motor apart. Love to have the RSR seals on my 84. How much does the service cost roughly?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Yes!
It can be done on a Valve adjust session. Just simply unbolt the shaft's pinch bolts with a 5mm & 8mm long handled Allen Wrenches, you will need to shorten the tip of the 8mm to fit the side to side shafts. Slide them out and send both rockers and shafts to DRC for a refurb. He would appreciate it if you could remove the pinch bolts/nuts and elephant feet of the rockers. No need to worry about keeping them in order the shafts are polished and rockers will get new honed bushings NOTE: on install, the torque is 20ft lbs not 13 as stated in the Bentley or PAG, 13 is for new cam towers ( if you can find one, they are nla ).
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 07-17-2016 at 10:36 AM.. |
Awesome - thanks for the details!
My pleasure.
It is a tight space, just make sure you put a towel under the valves just in case you drop the shafts as they will be slippery. I found the spark plug boot remover tool to be quite helpful to grab the shafts and at times you can use the empty space at the adjacent shaft hole to help manipulate it out/in
I think I am going to drop the motor and trans to install an Aluminum Pressure Plate that I have this winter and I will do it then along with some other oil leak stuff....and paint the engine compartment and and and...
Oh boy, that slippery slope :-(
