-   -   Need a Good Idea for Mounting O2 Sensor Wire on Electromotive Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/921387-need-good-idea-mounting-o2-sensor-wire-electromotive-setup.html)
Tidybuoy 07-11-2016 10:19 AM
I'm looking for any good ideas for mounting the O2 wiring on my Electromotive Setup.
See pic below: The oxygen sensor that came with this kit has a very short wire and then a huge connector that has to be mounted in the driver side rear wheel well. I hate the way this particular system is setup as it would have much easier if the wiring on the sensor end was longer than 1 foot.
That said:
1) anyone have a good idea or know of a good bracket that I can use to mount this better?
2) Is it possible for me to buy another oxygen sensor with a longer wire and eliminate the huge connector that came with this setup?
Wiring that I need to mount securely:
http://forums.pelicanparts.com/uploa...1468256852.jpg
Sensor & Controller (excluding the gauge): I have mounted the controlled at the rear fuse box where CDI used to be:
http://forums.pelicanparts.com/uploa...1468256938.jpg
JJ 911SC 07-11-2016 11:52 AM
Vern,
I was not impress by the short leash either.
On the engine tin (skirt) I cut the hole (by #1 spark plug) open, put a grommet around the cable and squish it in the holes. I may have had to enlarge the hole.
Made the connection between #1 and #2 spark plugs.
If the cable was longer I could have hide the connectors behind the fuse cover.
http://forums.pelicanparts.com/uploa...1468262652.jpg
http://forums.pelicanparts.com/uploa...1468262737.jpg
timmy2 07-11-2016 12:15 PM
Engine tin grommet the sensor can pass through is what I did as well.
May have had more length on the Bosch O2 sensor that came with my innovate unit.
Tidybuoy 07-11-2016 01:14 PM
Thanks Guys!
I will work on this a bit. I initially drilled the hole in my tin to be equal to where the hole is on the Carrera's but at the time, I did not notice the short O2 wires. I may just have to start over.
Vern
