-   -   911 Gauges for a backdate project (http://forums.pelicanparts.com/porsche-911-technical-forum/921446-911-gauges-backdate-project.html)
1ricardo 07-11-2016 05:44 PM
Dear Friends,
I´m backdating a 1978 sc into a 1973 and i would like to fit the ´73 gauges on the car
Problem is that the actual car use a electronic Speedometer and the ´73 speed gauge that i have is mechanical
So, how do i solve this problem?
Ultrafast993 07-11-2016 06:47 PM
Talk to NHS speedo or with Palo Alto Speedo, they should be able to help you., cheers, Stef.
cnielsen 07-11-2016 08:20 PM
Yes, they can cosmetically change your gauges to look like the 73 gauges.
Cairo94507 07-12-2016 05:08 AM
Palo Alto Speedo did all of my gauges and I converted my cable driven speedo to a later electronic speedo so I could add the extra digit on the odometer to keep the actual mileage accurate. Early cars just went to 99,999. Hartmut did the conversion by adding a VDO converter which changes the gear driven inout to electronic output for the speedo.
