Dear Friends,
I´m backdating a 1978 sc into a 1973 and i would like to fit the ´73 gauges on the car Problem is that the actual car use a electronic Speedometer and the ´73 speed gauge that i have is mechanical So, how do i solve this problem? Thanks |
Banned
Talk to NHS speedo or with Palo Alto Speedo, they should be able to help you., cheers, Stef.
Yes, they can cosmetically change your gauges to look like the 73 gauges.
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Palo Alto Speedo did all of my gauges and I converted my cable driven speedo to a later electronic speedo so I could add the extra digit on the odometer to keep the actual mileage accurate. Early cars just went to 99,999. Hartmut did the conversion by adding a VDO converter which changes the gear driven inout to electronic output for the speedo.
'71 914-6 #0372 '17 Macan GTS |
