Can '81-84 sport seats be used in an '85 Carrera?
I'm trying to increase my headroom a bit. Are the older 81-84 seats a bit lower, or is the difference between 84 and 85 seat height only in the rails? And will the older sport seat work? Is it a straight replacement, or is any modification required between the sliders and the seats? Thanks!
Old 07-12-2016, 11:59 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I think you will be just fine both are model Carrera, should have the same base rails.
I would measure the seat rails against the base mounts. Take a note of the rail positions, they are not even at the rears.
'85 Carrera Targa
PCA/POC
Old 07-12-2016, 12:08 PM
Checked out
McLovin's Avatar
Straight replacement.
Old 07-12-2016, 01:08 PM
80-84 doesn't have seatbelt receptacle on sliders - they are floor mounted in those cars.
So when you say straight replacement Mclovin - are you swapping rails from the 85?
I'm interested in doing this myself
Old 07-12-2016, 01:26 PM
Banned
Easy fab job for seat belts swap. Def sit lower in the seat. I may have some cores avail for cheap if looking for manual sport seats?
Old 07-12-2016, 01:45 PM
vintagecarlover - I'm gonna try a fixed Sparco and if that doesn't do what I want I'll PM you
Old 07-12-2016, 02:13 PM
gtc gtc is offline
abides.
gtc's Avatar
You can't easily remove the rails from the '85 seats. You would probably buy an adapter from brey krause, or I believe there is a factory part, that is sandwiched between the rails and the seat that provides an inboard seat belt mounting point.
Edit: see BK R-9005 or this thread for factory part.
Graham
1984 Carrera Targa
Old 07-12-2016, 02:21 PM
