-   -   tire pressure (http://forums.pelicanparts.com/porsche-911-technical-forum/921567-tire-pressure.html)
ourv12 07-12-2016 03:32 PM
tire pressure
I just bought new Dunlops for my '84 911 carrera turbo look. The tires side wall reads 51psi max .Do I set them all to 51psi or go by the vehicle manufacture sticker in the engine bay which recommends 29psi front and 36psi rear?
Joe Bob 07-12-2016 03:42 PM
29/36.........do donuts in a parking lot, use an IR gun and measure temps, inside, mid and outside. Adjust as needed.
Bill Verburg 07-12-2016 03:43 PM
You will have to experiment to find what is best for you, the side wall # is a max, not what to use.
I find something like 33-34 front and 34-35 rear hot to work pretty well for me.
a few rules of thumb
to reduce under steer raise the front pressures and/or lower the rears
to increase comfort lower front and rear
if you want to get more into it get a tire pyrometer
center hotter than edges - too much pressure
edges hotter than center - too little pressure
inner edge hotter than outer - too much neg camber
outer hotter than inner - too little neg camber
tire temp too high in general - pressure too low, tire too narrow, springs/sways too soft at that axle
fronts hotter than rear - under steer
rear hotter than front - over steer
86 911 Targa 07-12-2016 03:49 PM
Tire pressure.
I've used 36R & 29F (cold) for decades.
I pump them up to 44R/35F hot,
park the car overnight,
then bleed them down.
Nice equal tread depth all around.
Gerry
Oh Haha 07-12-2016 04:08 PM
My SC liked 32 front, 35 rear.
Also, my condolences on the loss of the officers at the courthouse.
DRACO A5OG 07-12-2016 04:16 PM
OEM 15" fuchs calls for 29/36
However on a recent alignment at West End Alignment, Darin recommends a 4 lbs difference front to rear, so he made it 31/35, note, I have 17"s
rokemester 07-12-2016 04:22 PM
Tire pressure threads are so nice and polite...a nice reprieve from the rancor found in the AC threads;)
Oh Haha 07-12-2016 04:29 PM
Yeah but he isn't trying to "reverse the tires". :D
Sorry, it was just sitting there waiting.....
