915 transmission
So I bought a 915 transmission for my VW Van 3.2 flat 6 project. I can not clearly see the transmission serial number but I think it is 7542256, does this make any sense?
I know it is post 1977 as it has an electronic sender. Anyone know what spec this would be? Dave |
gearhead
I suspect it was converted to electronic speedo. That's a 1974 serial number.
Is it a mix of mag case and aluminum case parts?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
doesn't look like a conversion and as I said, serial number is not clear. Looks to be an aluminium case. Is there any other way of telling?
Member 911 Anonymous
Post a pic of it. Maybe that will help us help you?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oh my, those numbers are toast
![]() Any way to get a close up of the bell housing especially where it mates to the engine or the clutch shaft portion? ^^^+1, when I cleaned my gear box I saw those numbers there too.
Dial 911
http://blueskymotorsports.com/index.phpoption=com_content&view=article&id=19&Itemid=6
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 07-19-2016 at 12:51 AM.. |
Link doesn't work for me? |
Dial 911
Hi...try again. I just re-cut and pasted 915 Series Porsche Transmission
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
