nostatic's Avatar
preferred "goo" for installing seals?
I pulled the rear lenses off, and noticed that there is an adhesive goo holding the rubber seals in place. It was apparent that I would need a similar goo to reinstall, as there really isn't much of a channel to hold the rubber part. Anyone have a preferred type/brand of stuff for this application? I'm also assuming I'll need to scrape the old stuff out...
Old 12-29-2002, 09:46 AM
carreradpt's Avatar
Nostatic, I have used the 3m weatherstrip adhesive. It worked real well for the same thing and it is water proof. There is also a spray on but the tube works best to put it exactly where you want to.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 12-29-2002, 10:03 AM
JmuRiz's Avatar
I agree, the 3M stuff in the tube works like a charm. The spray adhesive doesn't work nearly as well (might be good for a headliner redo, but not much else). Just make sure you put it where you want it to stick...because it sure does stick. Good luck
Nathan
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 12-29-2002, 11:55 AM
