Stomski shift coupler- do they make a difference
Hi
As with all 911s selecting a gear can be less than confidence filling. Will the stomski coupler make a difference?? Thanks
Nicely built, long lasting even though the stock ones last 30+ years. Worth the price? Prolly.
Under the radar
Nice piece of engineering. However, for about $10 or $15 you can replace the rubber bushings with harder material, which will probably work well.
I machined new bushings out of aluminum when my bushings died. No slop in my coupler.
This is the last try before I consider a rebuild. |
Under the radar
![]() What are your symptoms?
Yes. All bushes done.
Fitted wevo 12months ago which has increased the difficulty in selecting gears. Yes, it has all been set up by an expert. I have tried other 911 and they are all notchy to a degree, however mine is spoiling my driving experience and enjoyment. I want to keep the wevo as I like the shorter throw and position of the stick. 👍 |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Racer
Over a sloppy stock one, yes. Over a stock coupler with bushings with no play? No.
I thought about getting one for my race car but rebuilt the stock one and it is precise with no play. The only thing the Stomski would do better is lighten my wallet more.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 07-20-2016 at 03:24 PM.. |
Todd
'81 SC |
Under the radar
Have you read this? Worth checking out before dropping the trans.
loose 6 mm stud in 915 gearbox
I have a Wevo coupler and Wevo internal shift gate on a rebuilt trans with factory short shifter. REALLY REALLY works well.
I HIGHLY recommended the Stomski or the Wevo. Both great products.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Insert Tag Line HERE.....
I disagree. No way a stock coupler with whatever kind of bushings you put in it can ever be as precise as the Wevo or Stromski version which is all metal. I promise you, yours has some movement in it that these types do not and will never wear out and get looser. One of the best upgrades you can do for the money.
Racer
The parts I used are here: WEVO vs. Stomski shift couplers? Here is a video of my coupler in action: https://youtu.be/O-QPUmSTmtk
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion Last edited by winders; 07-20-2016 at 08:13 PM.. |
WEVO PSJ +1
Can't comment on Stomski but seems very similar in design. The decades-old design of the shift coupler can be, and has been, improved with modern CNC technology. Whether or not that improvement is perceptible and meaningful is probably personal opinion. It could be overkill. My shifting, however, improved greatly with a PSJ.
Jason - Austin, TX 82 911 SC targa (gone, but not forgotten) 92 968 coupe |
abides.
Lol... U-joints aren't exactly modern technology. I think they've been around a lont longer than our shift couplers.
Graham 1984 Carrera Targa |
Cars Ruined My Life
I have rennshift with stomski coupler. I could do as good without the couple by just rebuilding the stock one with bushings.
Sent from my iPhone using Tapatalk |
Ok so it's been setup/adjusted again and the issue "we" think is the synchro S.???
5th to 4th is difficult. 5th to 3rd is ok 4th to 5th is ok Linkage has been adjusted both ways and gives the same result. The problem is there in all positions. Can the scynros be up rated when replaced? |
Banned but not out, yet..
You need to find a new expert. I added a Stromski and it made no real difference, but then it was already shifting at an 8 out of 10. Good luck.
An air cooled refrigerator. ‘Mein Teil’ |
You need to look at the whole shifting mechanism...as a system. It all has to be in good shape and adjusted properly to work well. If all the wear parts (bushings, etc.) are worn and the shifter is not adjusted properly...I.E. if it's like most after 30-40 years of driving...and you just install a new coupler..you will likely be disappointed in the results. On the other hand....if your system is already in excellent shape and you install one new bit......the change may be slight.
I had a 77S that shifted ok, but throws were long and a little vague. I replaced all bushings and installed a WEVO shifter. After spending a bit of time adjusting things.......excellent shifting. ....but the starting point was sloppy and I replaced all the wear items. Noticeable difference However, I once bought a 66 912 that shifted like you were stirring oatmeal and you could occasionally find a gear or two, if persistent. When I dug into it, I found that the coupler bushings had been replaced with sections of garden hose....that was bad enough...but one of them had fallen out..............In this instance, because the starting point was so bad..replacing the bushings and adjusting really made a huge difference.....you could find a gear...without divine intervention........ Your results may vary.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
