rs911t's Avatar
Cleaning valves
Warning - newbie question ...
I have my carbs off for cleaning/rebuilding. Also pulled the manifolds for cleaning. Now that I have access to the intake valves, should I do anything to clean off some of the deposits?
Greg
Old 12-28-2002, 08:42 AM
Let sleeping dogs ... lie. You are more likely to dislodge some carbon and have it stuck in the valve seats and cause a compression leak.
I would not do any more than cover it up, and leave it alone.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-28-2002, 09:30 AM
a carbed motor should have a cleaner intake/valves than say a cis motor.
you might add some snake oil to your fuel before your next oil change. yelcab is correct, a big chunk may cause serious trouble.
i would let it slide. if you must, i believe bmw used walnut shells and gave a free one time cleaning.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 12-28-2002, 09:57 AM
tobluforu's Avatar
Put it back together and then add full bottle techron to half a tank of gas. Drive it to almost empty. Fill up and drive till empty. Then change oil. Some people spray water into intake while engine is running. If you have carbs, go for it. The water will break up any carbon. Make sure you keep car reved when you do this. I do it on my mfi. Nice black crap comes out. Only do it before your about to change oil.
Old 12-28-2002, 10:39 AM
rs911t's Avatar
Thanks guys. I'll let it lie and run some Techron after she's all buttoned up.
Greg
Old 12-28-2002, 02:41 PM
