Caveman Hammer Mechanic
Rear wiper Install?
Hello,
I am going getting ready to install a rear wiper on ElChup. My biggest question is mounting the motor to the decklid hinge. Which holes are used, I have the motor that mounts to the hinge, but the holes don't line up with the motor baseplate. Anybody have some detailed pictures of the mounting? Also the rear grill on some cars have a cutout for the wiper shaft, any idea which years? Thanks eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Rear wiper.
For your '84 M/Y.
As I recall, if you do not have an existing rear wiper, the rear condenser will also have to be replaced with a compatible rear wiper condenser. ![]() Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 01-22-2019 at 11:28 AM.. |
Rescuer of old cars
I did this on my '84 something like 6 years back. I'll look to see if I have any pics of the hinge mounting. But I don't recall any problems on my car. Seems like it just bolted up. Can't take new pictures now, I sold the '84 last week.
The rear grills all can be notched for the shaft. If you remove it and look at the underside, the cutout shape is molded in. Use a Dremel or similar and just trim it to the line molded there.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 01-22-2019 at 11:33 AM.. |
Rescuer of old cars
Oh yeah, I forgot to mention the condenser issue, assuming you still have A/C in it. I did replace mine with the notched condenser.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
No A/C, that stuff went to the dump in a giant wad of rust and corrosion. My issue is how the motor base bolts to the hinge...
Rescuer of old cars
Some pictures of the hinge mounts (and a hinge that had no holes) here -> Need pictures of installed rear wiper assembly
Figgered it out, used the slots instead of the drilled holes!
